Re: sediment bowl
Posted by Bob M on September 01, 2001 at 13:29:43 from (66.66.72.246):
In Reply to: sediment bowl posted by Dale on August 31, 2001 at 18:41:52:
Dale - If the bowl stays filled with air even after you open the shutoff valve, just start the motor. As soon as the float level drops a little in the carburetor, the air in the sediment bowl will bleed out thru the carb and the sediment bowl will fill by itself in manner of a few seconds.
Post A Followup
: Re: Re: sediment bowl
