Re: RE: Farmall H clutch pilot bearing lubrication
Posted by Zonie on September 01, 2001 at 19:13:23 from (64.12.104.36):
In Reply to: RE: Farmall H clutch pilot bearing lubrication posted by Slappy on August 31, 2001 at 04:05:23:
Just a quick comment...On my H the grease fitting for the pilot bearing is inside a hole drilled in the edge of the flywheel. Is it possable that your is filled up with grease or dirt where you might miss it? the zirk fitting doenot stick out past the outer surface of the flywheel.
Post A Followup
: Re: Re: RE: Farmall H clutch pilot bearing lubrication
