Re: Farmall A Starter Problem?
Posted by The Red on September 02, 2001 at 05:17:46 from (12.84.239.96):
In Reply to: Farmall A Starter Problem? posted by Rick on September 02, 2001 at 03:57:33:
More than likely the brushes are worn. If the cable from the starter switch to the starter is more than 25 years old, there might be enough corrosion in the wire to prevent a current flow. They can look good on the outside but be rusted in the inside.
Post A Followup
: Re: Re: Farmall A Starter Problem?
