Re: Carb frustrations!!
Posted by Phil Auten (Tx) on September 02, 2001 at 16:30:23 from (63.173.243.19):
In Reply to: Carb frustrations!! posted by J3nut on September 01, 2001 at 18:10:27:
If you leave the bowl off and raise the float, will it shut off the gas? If not, and if the needle and seat are brass, tap the needle into the seat lightly a couple of times. This will cause the seat to be shaped to fit the needle.
It does sound as if the float is dragging on the bowl though.
Good luck,
Phil
Post A Followup
: Re: Re: Carb frustrations!!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
