Re: Farmall M Electrical
Posted by The Red on September 04, 2001 at 11:37:14 from (206.246.187.2):
In Reply to: Farmall M Electrical posted by Aaron on September 04, 2001 at 10:56:09:
My guess is that you didn't have tight connections when you switched to positive ground. The starter will crank the same regardless of the ground settup. Switch it back to positive ground and bolt your ground cable to one of the starter mounting bolts. Make sure the connection is clean.
Post A Followup
: Re: Re: Farmall M Electrical
