Re: 560 diesel tappet settings?
Posted by Farmer-Gene on September 04, 2001 at 14:18:48 from (207.230.202.175):
In Reply to: 560 diesel tappet settings? posted by wally on September 03, 2001 at 19:39:34:
.027 both intake& exhaust with engine hot. Torque head bolts in sequence to 110-120 ft lbs, retorque after engine has been run and is at operating temp. It may seem a pain in the butt to retorque later when warmed up, but it'll save you from having to replace a blown head gasket.
Post A Followup
: Re: Re: 560 diesel tappet settings?
