Re: Taking a bath with an H
Posted by The Red on September 04, 2001 at 15:25:45 from (12.84.239.141):
In Reply to: Taking a bath with an H posted by Michael Soldan on September 04, 2001 at 13:47:22:
Mike removing the steering column and the gas tank will be easier than you think. Don't be surprised if the entire stud unbolts from the gas tank. That has been my experience in the past. The bear will be removing the rear gas tank support bracket if the 3 bolts that bolt it to the deck are badly weathered.
Before you reinstall the steering post, make sure the foot print is filed clean and the decking is filed clean so you get a good ground. As you add the light box and the light bar, make sure you are clean metal against clean metal so you get a good ground on the lights and a good ground on the light box if you have the low charge 4 position light switch.
Post A Followup
: Re: Re: Taking a bath with an H
