Re: Re: Re: super (m) rpm
Posted by Dale13 on September 04, 2001 at 15:53:00 from (207.49.223.178):
In Reply to: Re: Re: super (m) rpm posted by bud barenie on September 04, 2001 at 06:47:45:
When you pull have someone watch your tires for sidewall flex,there should be some unless you haave 8 ply tires.Also at the end of the pull before you drive away from the sled too far look at the holes where you spun out. Perfect pressure in the tires would leave flat a bottom in the holes. If rounded too much psi,if the side are all thats digging too little.
I pull a Super M in 6000,6500 and 7500,no suitcase weights, stock rpm. They use a 8 foot cable and the front only comes up in 7500.Thats 8 sets of wheel weights.I try not to touch the brakes cause the only times I ran out of power was when those wonderful disc brakes locked on 10 feet from a full pull with the box all the way up!!
Post A Followup
: Re: Re: Re: Re: super (m) rpm
