Re: 2424
Posted by azjbird on September 05, 2001 at 03:25:09 from (12.83.103.126):
In Reply to: 2424 posted by scooterhead on September 04, 2001 at 06:22:18:
Sounds like fun! Wish I had the loader on mine. Check the fluid level on either side of the main trans case. the pipe plug. The fill point is behind the seat on the right. If you still have no go, the hose that goes into the tail housing under your right leg has A screen in it where it meets the case. And yes Scoot, the three point has down pressure. Try Binder Books, they treated me well. J.
Post A Followup
: Re: Re: 2424
