Re: Re: Model M Coil Meltdown
Posted by Harry on September 05, 2001 at 12:45:39 from (152.163.204.183):
In Reply to: Re: Model M Coil Meltdown posted by The Red on September 05, 2001 at 08:31:13:
The Red, thanks for the info. I'm not able to check on the voltage of coil till this weekend, but I feel certain that it is a 12 volt coil. Is it stamped on the coil some where? I do feel that I do not have a resistor inline. Also, do I swap out the same Condensor that is in there now? Thanks.
In case you didn't get my return message recently,
you were right on when I ask about my Big Red gears being stuck. Removing the gear shift work great. Really appreciate it.
Post A Followup
: Re: Re: Re: Model M Coil Meltdown
