Re: Re: Re: Re: Outer bearing on rear axle of M
Posted by randy hall on September 05, 2001 at 19:32:30 from (63.237.50.48):
In Reply to: Re: Re: Re: Outer bearing on rear axle of M posted by jiM on September 05, 2001 at 10:47:48:
the bearing is a 214 shielded on one side. if you what a better bearing get a 1214 it has more balls for more load carring capacity. if i were you i would call steel wheel ranch and get a good used one for about a fourth of new. good luck
Post A Followup
: Re: Re: Re: Re: Re: Outer bearing on rear axle of M
