Re: Outer bearing on rear axle of M
Posted by Bill on September 05, 2001 at 20:29:35 from (156.46.214.97):
In Reply to: Outer bearing on rear axle of M posted by jiM on September 05, 2001 at 07:47:35:
I did one this summer. Loosen up your hub on axel and remove wheel. This is a real bear of a job. Check that your keyway is ok, not getting loose. for the seal just remove endcap and replace seal, it like 4 1/2" bolts, pretty easy. The bearing is another job. in the book it says to remove trans cover, this means seat steering post, gas tank etc. A shortcut is to drain rearend( a good time to change fluid anyway)and remove the PTO shaft. then use this for access to get to the axle retaining bolt. this is bolted thru the bull gear and holda the axle in. It uses an 1 1/8" socket I belive.after bolt is removed, remove the bolts around the outside that hold the axle housing and remove. pull straight out, a cherry picker is nice to use for this. remember to block the bull gear up inside the housing with a piece of 2x4. It seems that you have to remove 2 split bearing retainerers from the inside of the axle housing. then give the axle a good rab with a big hammer cussioned with a wood block. Remove bearing and race and reasemble. The bearing was about $75 from dealer, seal about $16.00. Check your axle for wear at both the bearing jounal and seal surface. Axle was $100.00 used. Both a M and 400 axle fit. It uses about 2 1/2 5 gal pails of gear lube. Not to bad of a job as a whole. good luck
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
