Re: Oil in Air Cleaner for M
Posted by Jon with an M on September 07, 2001 at 06:41:49 from (158.114.92.203):
In Reply to: Oil in Air Cleaner for M posted by Alabama on September 07, 2001 at 06:09:20:
It should not draw the oil out of the cleaner. Is the filtering material still in the body of the cleaner? Is it clean? You can take the cleaner body off and soak it in kerosene to clean it.
Also, does it smoke now if you run it without oil in the cleaner? If it does the problem may not be related, do a compression check, you may have a stuck ring.
How long have you had the tractor? Have you put many hours of runtime on it?
My thoughts.
Post A Followup
: Re: Re: Oil in Air Cleaner for M
