Re: Super A Rear Wheel Removal
Posted by big fred on September 07, 2001 at 14:44:28 from (12.13.226.13):
In Reply to: Super A Rear Wheel Removal posted by Tyler (MD) on September 07, 2001 at 13:40:36:
You should be able to just take off the rim and tire, if you can bust the nuts loose. A rim and tire will be quite manageable, weighing maybe 100 to 150 lb total if you have it drained. The tires and rims on my B weighed in at 180 and 190 lb with some fluid still sloshing around in them. If you need to remove the weight, rig some kind of support for it, my choice would be a shop hoist, as you said, they are about 130-140 lb.
Post A Followup
: Re: Re: Super A Rear Wheel Removal
