Removing Steering Shaft from '41 Model B Farmall
Posted by Robert C. Opiela on September 07, 2001 at 21:09:27 from (208.152.175.163):
I am fixing up a 1941 Farmall Model B. I would like to disconnect the steering wheel shaft from the u-joint near the steering gearbox. The u-joint appears to have a key-way and also could be a roll-pin driven thru the u-joint coupling. Does anybody know if this is a tapered pin? Some illustrations show a bolted connection here, but this is not. I was wondering if it might be a button head rivet, maybe you have to grind off the head to drive the pin out??? Any help?? Thanks..
Robert
Post A Followup
: Re: Removing Steering Shaft from '41 Model B Farmall
