Re: farmall h tractor needs help
Posted by The Red on September 08, 2001 at 05:06:32 from (12.84.239.190):
In Reply to: farmall h tractor needs help posted by redpowerfan on September 07, 2001 at 15:28:27:
Do you have coil/distributor or magneto settup? In either settup, it sounds like your timing is not advancing when you increase your RPM. At 1850 RPM, the timing should advance to almost 40 degrees.
Post A Followup
: Re: Re: farmall h tractor needs help
