Re: H Farmall Dies
Posted by The Red on September 08, 2001 at 05:14:44 from (12.84.239.190):
In Reply to: H Farmall Dies posted by Mark B on September 08, 2001 at 03:11:41:
Mark I would suspect two problems. Either the main spark plug wire from the coil to the center of the distributor cap is bad, or the connections where that wire pushes in either end on the coil or the cap are bad. Could be a combination of the two.
Post A Followup
: Re: Re: H Farmall Dies
