Re: So what does everybody use their tractors for?
Posted by Andy Martin on September 08, 2001 at 07:13:52 from (63.27.17.232):
In Reply to: So what does everybody use their tractors for? posted by Sam on September 07, 2001 at 12:31:53:
I am semi-retired and farm with Farmalls only.
Mow hay with my WF M and NH 469 haybine.
Rake when required with C and IH 46 hayrake.
Bale with my Grandpa's M and JD 348 square baler (wire tie). 10,000 bales this year.
Haul hay with same WF M or NF M and NH bale wagon (one-man stacker).
Plow with WF M with 6 wheel weights and IH 3 bottom trip plow.
Disc with Grandpa's M and JD 9 ft disc.
Plant with either M and JD 13x7 drill.
Cut brush trees with 39 M with vintage Farmhand loader and tree saw.
Brush hog with M with M&W hand clutch or C.
Mow grass with A with IH 5 ft finish mower.
Grade drive and loose dirt with Cub and front blade.
Hay rides with WF M or NF M. They are the only two with good lights.
Stationary 3-1/2 - 5 IH is used for amusement. Would like to get it hooked up to a jack shaft to run the trip hammer.
The O-6, another M, two diesel M's, Super MTA-D, Super H, two H's, Super C, B, Super A, F-12, F-14, 100, 300, two JD A's, JD B, and Allis B, CAT D2, and CAT 12 just sit and watch.
By the way, do you know why there are more JD's collected than Farmalls?
Because the old Farmalls are still working, earning their living.
Post A Followup
: Re: Re: So what does everybody use their tractors for?
