Re: RPM check
Posted by another idea on September 08, 2001 at 19:58:58 from (64.111.94.109):
In Reply to: RPM check posted by J3nut on September 08, 2001 at 10:24:17:
J3nut: Do you have another tractor that has a good RPM tack?? If you run that at your desired RPM and use a normal timing light hooked to it and then flash the timing light over unto your super C, you can then vary the C's rpm until it also is in sync. Presto your done. Thats using another engine as a "master". It's cheap and quick. Sorta like putting both engines in a twin engine airplane into sync with each other.. Ones a master and the other is a slave. ralph
Post A Followup
: Re: Re: RPM check
