Re: THERMOSTAT
Posted by The Red on September 09, 2001 at 04:51:06 from (12.84.239.242):
In Reply to: THERMOSTAT posted by ken on September 08, 2001 at 23:59:47:
If you are speaking about the casting with the curved pipe that connects to the top of the radiator, that is where the thermostat is located. The original IH thermostats were a large assembly. On the Hs and Ms, I usually have to use a chisel and tear into them so I can take a pair of offset plyers and pry them out.
Post A Followup
: Re: Re: THERMOSTAT
