engine oil pressure
Posted by TractorChuck on September 09, 2001 at 12:21:32 from (63.27.37.202):
My '44 H gets 5 lbs hot idle, 25 lbs hot at 3/4 throttle. I put a new gauge on her because the old one was sprung ( wouldn't go to zero), my question, Is this enough oil pressure to not cause damage, and also, the gauge is supposed to be connected with the 1/8th inch bourdon tube, I have it attached with the 1/4 inch oil tube, would this cause any pressure change? I've been thru the pump, lapped the cover flat, installed a new pressure relief spring and valve, cleaned it, I did not check the tolerances of the gears to each other or to the inside of the body ( didn't get my manuals until a week after I did thi). I did notice a slight play of the shaft, vertical movement, the rest seemed tight. I also put a new paper gasket on the cover, pump wouldn't turn without it, and finally a changed to HD SAE 40 wt. oil. Any suggestions? thank's TractorChuck
Post A Followup
: Re: engine oil pressure
