504 unloading valve
Posted by J. D. Humm on September 09, 2001 at 13:27:46 from (12.64.31.116):
My Farmall 504 fast hitch will not lift until you activate one of the remote outlet levers. It will then lift easily whatever is attached to the tractor. Les Repair mentioned the unloading valve is the problem. The part # is 376 762 R1. This part is no longer available through Case IH. My service manual concurs with Les' opinion. Does anyone know where I can get a NOS valve or known to work used valve?
Post A Followup
: Re: 504 unloading valve
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
