Re: Re: Re: superA w/delco12V Alt.
Posted by Bob M on September 09, 2001 at 20:33:36 from (66.66.72.246):
In Reply to: Re: Re: superA w/delco12V Alt. posted by Bare on September 09, 2001 at 15:38:46:
Joe's right - you can use the existing ammeter "as is" on 12 volts. But a voltmeter will work fine too - wire it up like this: 1-Wire from the alternator BAT terminal direct to the starter switch. 2-Voltmeter "+" connect to the SWITCHED side of the ignition switch. 3-Voltmeter "-" connect to any good ground. ...Bob M
Post A Followup
: Re: Re: Re: Re: superA w/delco12V Alt.
