Re: Re: Re: Re: Re: Farmall M wiring at a minimum
Posted by The Red on September 10, 2001 at 09:46:12 from (206.246.187.2):
In Reply to: Re: Re: Re: Re: Farmall M wiring at a minimum posted by Lance on September 10, 2001 at 09:41:20:
You didn't mention the alternator before! Settup should be for negative ground. Hot wire should go to the negative post on the ampmeter. The alternator wire, the coil wire and light switch wire should be on the positive post of the ampmeter.
You better get a resistor or you will burn out that 6 volt coil!
Post A Followup
: Re: Re: Re: Re: Re: Re: Farmall M wiring at a minimum
