Re: Fan assy. Farmall B
Posted by Haas on September 10, 2001 at 13:35:34 from (129.37.117.122):
In Reply to: Fan assy. Farmall B posted by Big City Bob on September 10, 2001 at 10:47:36:
Dave T is giving you good info. I'll add a little. There is no seal on the shaft. Centrifugal force keeps the oil at the outside of the hub when it is turning, so none comes out. You are likely overfilling the hub. Fill it like Dave says and you should be OK. It only holds a small amount.
Post A Followup
: Re: Re: Fan assy. Farmall B
