Re: Re: 460 gas to diesel
Posted by ohioron on September 10, 2001 at 16:01:44 from (152.163.207.189):
In Reply to: Re: 460 gas to diesel posted by Tim Malin on September 10, 2001 at 14:24:03:
Tim, thanks for the answer. I guess I wasn't very plain. I meant taking out the bad gas engine and replacing it with a diesel engine. It seems when done on a truck the trans, rearend, radiator and other things have to be changed because of rpm, torque and other differences. That was what I was afraid of getting into if I switched to diesel. But you say it will bolt right in and work fine. Thanks I'll look into it. Ron
Post A Followup
: Re: Re: Re: 460 gas to diesel
