Re: Re: Re: Re: Re: All kinds of confusion on the M!
Posted by The Red on September 13, 2001 at 06:21:46 from (206.246.187.2):
In Reply to: Re: Re: Re: Re: All kinds of confusion on the M! posted by Jeff on September 13, 2001 at 05:52:28:
Jeff ignore the black wire. That is for the coil distributor system. Only hook up the blue wire from the bat terminal on the voltage regulator to the negative post on the ampmeter for positive ground.
If you have only a 3 position light switch (off, dim, bright), ignore the yellow wire. If you have the 4 position switch (low charge, high charge, dim lights, bright lights), then hook the yellow wire from the field post on the generator to the screw at the bottom of the light switch adjacent to that flat looking resistor. That will give you low charge capability. You probably won't need it though.
Post A Followup
: Re: Re: Re: Re: Re: Re: All kinds of confusion on the M!
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
