Re: FARMALL H TIRES
Posted by Denny Frisk on September 13, 2001 at 09:56:51 from (12.4.181.2):
In Reply to: FARMALL H TIRES posted by LOU on September 13, 2001 at 05:53:13:
I used to BUY tires for FARMALL. TUBELESS TIRES - DON'T USE THEM. The tires are fine, IF You put a tube in them! I can't begin to tell You how many flat tires We had on tires before the tractors even shipped. Don't Be CHEAP! You can reuse the tube You know! Even if they're patched. And I suppose You could powder coat the rims. Be expensive to do the rear's.
Post A Followup
: Re: Re: FARMALL H TIRES
