There are two drains, one at the rear bottom below the PTO. The other is a the center front where the joint to the big U frame attaches to the transmission housing. The rear is the main drain. There is a level plug on the side. I think it's on the left side somewhere in the area of the brake pedal shaft. I'm not sure what the capacity is, but I think it would be the same as the Farmall H. I know the I-6 holds 14 gallons. I think the I-4 is probably about half of that. The data book I have does not show the transmission capacity.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
