Re: Re: 300 u
Posted by Denny Frisk on September 13, 2001 at 13:13:51 from (12.4.181.2):
In Reply to: Re: 300 u posted by 300 Randy on September 13, 2001 at 10:18:48:
Dad ran Hy-Tran in His '51 M for a few years. It works, It leaks a little more around the old seals & gaskets, and it took forever for the gears in the transmission to stop so You could shift into gear. He finally replaced it with 90 weight.
Post A Followup
: Re: Re: Re: 300 u
