Re: Farmall A Steering Problems
Posted by Chris B. on September 13, 2001 at 19:46:34 from (64.24.62.181):
In Reply to: Farmall A Steering Problems posted by LarryE on September 13, 2001 at 17:21:49:
This may have already been directly or indirectly referred, but you may want to check your toe-in. When I helped my friend replace his worn out balljoint we didn't set the toe-in correctly and as a result the wheels were splayed out. Upshot of this is, we couldn't keep the tractor straight down the road in high gear and turning was more difficult at slower speeds.
Of course, slop in the gearbox or balljoints won't help any.
Chris B.
Post A Followup
: Re: Re: Farmall A Steering Problems
