Re: Can't start my tractor
Posted by Bob M on September 13, 2001 at 20:01:42 from (66.66.72.246):
In Reply to: Can't start my tractor posted by Big M on September 13, 2001 at 18:28:59:
Before you do anything else, try this: Grab the fan blade and try to turn the motor BACKWARD a fraction of a turn. Or put the tractor in high gear then push it backward an inch or two - enough to cause the fan blade to move a bit. Then try to start it using the starter. If the starter now works, the starter drive (bendix) was jammed.
This happens sometimes when the bendix wears out - means the bendix should be replaced.
Post A Followup
: Re: Re: Can't start my tractor
