Re: Farmall A Steering Problems
Posted by A-BOB on September 14, 2001 at 06:49:11 from (64.12.107.42):
In Reply to: Farmall A Steering Problems posted by LarryE on September 13, 2001 at 17:21:49:
You've received some pretty good advise. I would try those suggestion first because they're the easiest to accomplish. However, if you still have the problem as I did, you'll need to open the gear box. The parts picture that BOB[PA] sent you will help. I found that the bearing on the top of the side of the steering gear shaft was worn and sloppy, I replaced it. The tapered steering gear shaft was slightly worn and I had built up and re-sized. The steering gear shaft goes through a bronz bushing. That was my primary problem which went away with a new bushing. The book sayes they are pre-sized, maybe they were when the book was printed, but now they need resizing. When I was done, I have about a 1/2" of play at the steering wheel which may be less than when new.
Post A Followup
: Re: Re: Farmall A Steering Problems
