Re: H turning over but not starting
Posted by The Red on September 14, 2001 at 10:28:08 from (206.246.187.2):
In Reply to: H turning over but not starting posted by Mike Shelton on September 14, 2001 at 10:19:20:
Assuming you have a distributor/coil systme, make sure you are getting juice all the way to the distributor side post. If you are then I would replace the condensor first. If that doesn't help, then I would suspect the coil has gone bad. Also make sure the point gap is not greater than .020. Otherwise they won't close.
Post A Followup
: Re: Re: H turning over but not starting
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
