Re: Generator is finally done.
Posted by Bob M - polarize it! on September 14, 2001 at 16:06:09 from (66.66.72.246):
In Reply to: Generator is finally done. posted by Jeff on September 14, 2001 at 15:15:20:
After the generator is mounted and all the wiring connected, polarize the generator. It only takes a moment to do and you will then be sure it's now correctly polarized!
Post A Followup
: Re: Re: Generator is finally done.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
