Re: compression on 450
Posted by shannon on September 14, 2001 at 18:25:51 from (199.224.85.232):
In Reply to: compression on 450 posted by Serviceman on September 14, 2001 at 17:18:04:
over sized rod bearings will do nothing to your compression. the only reason you would need oversized rod bearings is if you grind your crank to remove gouges, correct concentricity problems or clearence problems. the lp head and high compression pistions should be fine if you retard the timing and set your mixture accuratly. (detonaton)
Post A Followup
: Re: Re: compression on 450
