Re: My '45 A Sounds Like a John Deere.....
Posted by Phil Auten (Tx) on September 15, 2001 at 10:50:58 from (63.173.243.86):
In Reply to: My '45 A Sounds Like a John Deere..... posted by ThatOtherGuy on September 14, 2001 at 18:28:40:
TOG,
Do a compression check to see if the problem is the compression in one or more cylinders. Remove the plug wires one at a time to see which cylinders aren't firing or aren't firing correctly. Like Red said, swap plug wires to see if they are the problem. Replace the cap and rotor on the mag. Replace all the plugs with at least two heat ranges hotter plugs. Check to see if one or more valves are sticking or for bent pushrods. Check and reset the valve clearances. Finally, if none of these things help, pull the head and have a machine shop check it for cracks, especially in the combustion chamber areas. If overheated, these engines are subject to that type of failure, BTDT.
Good luck,
Phil
Post A Followup
: Re: Re: My '45 A Sounds Like a John Deere.....
Today's Featured Article - The Great Escape - by Dave Hollrah. It all began Monday with a little baling of second crop on the lake shore field, and as I drove out past my sister and her hubby's place, this small calling sound could be heard from the general direction of their manure pile. Out of the yard, over the cows and bale piles, through the dozer piles, poplars, and brush, out onto the ditch grade road, past the noisy 6.2 diesel engine pulling my well traveled Suburban along. Well it sure didn't take me long to figure out what it was because I alrea ... [Read Article]
