Re: H turning over but not starting
Posted by Bernie on September 15, 2001 at 16:37:50 from (209.91.32.156):
In Reply to: H turning over but not starting posted by Mike Shelton on September 14, 2001 at 10:19:20:
Mike Start with basics, First make sure your start switch is in the on position, as you know you can crank the engine with the switch on or off. Check for spark, disconnect coil wire from distributor cap,and ground it to the block and crank the engine, you should have a spark jumping from the coil wire to ground. If you have this,it indicates that your points are receiving power and are opening and closing. If you don't have spark, Insure the points are first gapped correctly and are opening and closing ,not welded together. Assuming the points are ok you will have to work backwards to a source of power from the distributor to the start switch. If you have spark, than check to insure fuel is getting to the carb, take off the carb air intake, pull the choke and crank the engine, fuel should start dripping out of the carb, this will tell you it's at least getting into the carb. If carb is the problem you can by pass it by pulling the plugs, make sure they are dry and squirt a little fuel in the cylinders, replace the plugs and crank it over again, If it starts up it will only run until the fuel above the pistons is used up. Hope this is helpful, if not e-mail me and I will try to help you. Had a similar problem on a H, I was working on just two weeks ago for a farmer in Vermont. Bernie
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
