F-14 rear rubber
Posted by JDM on September 16, 2001 at 07:00:29 from (206.74.34.72):
I was fortunate enough to be able to buy a set of rear star shaped hubs with the rims for my 14.The rims were about shot but possibly could be fixed up.Well instead I found a set of 40 inch blank rims which i was assured of they would work but the section where the clamps grab is bigger by 2.5 inches.Was still assured by the guy I got them from it would work but would have to flip around the clamps until I found the right combo that will work.Anybody ever done this before or will I end up doing something else.I fooled with it a littlethis morning but Im starting to wonder if they will work.Any thoughts
Post A Followup
: Re: F-14 rear rubber
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
