glow plug indicator
Posted by Wes Cook on September 17, 2001 at 13:59:23 from (192.234.68.73):
I recently inherited an IH 3444 tractor. It had sat for 10+ years in a field. I got the engine running after having the injectors rebuilt. The glow plug wires and indicator have been removed. Can I still get the indicator? The engine cranks fine now, but I'm sure I'll need glow plugs when it gets cold.
Post A Followup
: Re: glow plug indicator
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
