Re: Super M running poorly
Posted by Charlie on September 17, 2001 at 15:02:42 from (209.130.137.94):
In Reply to: Super M running poorly posted by Dale (MI) on September 17, 2001 at 13:55:27:
Oil running out of the manifold sounds like you should pull of the valve cover and have a look. Could be a bent push rod and the valve(s) are not closing. You may also want to do a compression test to see if all the cylinders are the same. In addition, anything running out of the manifold suggests a leaky manifold. If there is a leak in the intake side it can cause the tractor to miss - the two that are missing are together and could be affected by the same leak.
Post A Followup
: Re: Re: Super M running poorly
