Re: H FRONT WHEELS
Posted by Bill Smith on September 17, 2001 at 20:41:58 from (128.242.4.59):
In Reply to: H FRONT WHEELS posted by LOU on September 17, 2001 at 20:12:00:
Bob is right, if you jack tractor up a little more than just the necissary 1 inch, then you should be able to work one bolt hole nub from inside to outside of hub one at a time. I presume your rim is mounted on the inside of hub. If it is mounted on outside of hub then you can just remove the three bolts from the rim and hub. I have done it without scratching paint but you have to be real careful.
Post A Followup
: Re: Re: H FRONT WHEELS
