Re: farmall tune-up
Posted by Bama Binder on September 18, 2001 at 13:58:06 from (206.5.110.200):
In Reply to: farmall tune-up posted by phillip weiland on September 18, 2001 at 12:22:44:
I would try your local Case I/H dealer to start with. NAPA may also have them. Check the sources on this site for other mail order dealers. There isn't that much that you need. Most kits that include plugs points condensor and rotor are about $20. Include $12-15 more for the distributor cap and plug wires. $20 if you feel you need a new coil, but the other stuff should get it running like a sewing machine if there are no mechanical problems.
Post A Followup
: Re: Re: farmall tune-up
