Re: Copper Or Steel Fuel Lines?
Posted by ED--GA. on September 18, 2001 at 17:43:36 from (209.214.64.45):
In Reply to: Copper Or Steel Fuel Lines? posted by TMAC on September 17, 2001 at 18:26:24:
Steel---If you have the old lines, heat the tips and remove fittings. Then solder to new lines using the original nuts and fittings. Don't do as I did the first time, I forget to slide nuts on the line before soldering ends on.
Post A Followup
: Re: Re: Copper Or Steel Fuel Lines?
