Re: M carb/gov again
Posted by Bob M on September 18, 2001 at 18:22:41 from (66.66.72.246):
In Reply to: M carb/gov again posted by Busch on September 18, 2001 at 14:05:57:
Sounds like a frustrated mechanic stuck a pop rivet in the carb inlet drip hole. (The drip hole should have a piece of felt in it.) Purpose of the hole is to drain excess gas if you overchoke and flood the carb. But it will also drip gas if the float level is set to high, the float has sunk or if the fuel inlet needle valve leaks. It will probably be worth your while to remove and open up the carburetor to see what's going on inside...
Post A Followup
: Re: Re: M carb/gov again
