Re: 1940 A
Posted by midus on September 19, 2001 at 16:13:29 from (209.115.125.133):
In Reply to: 1940 A posted by pete cormier on September 19, 2001 at 15:30:16:
Is the tank clean ( no rust ) and is the sediment bowl clean?
When it does this check to see if you are getting fuel to the carb.
If it is not fuel related look at the ignition. A bad plug, wire, cap, rotor or condenser can act up when the temp. rises. It will cause the same symptoms that you are describing.
good luck
Post A Followup
: Re: Re: 1940 A
