Re: BAD FLOAT??
Posted by J3nut on September 20, 2001 at 19:18:51 from (64.12.104.46):
In Reply to: BAD FLOAT?? posted by THatOtherGuy on September 20, 2001 at 18:28:26:
Make sure the fuel bowl gasket is not blocking the fuel bowl vent. Mine (Super C with a Zenith) vented though a hole in the bowl, through the gasket, then through a hole in the throttle body. Problem was the gasket was not cut properly and blocked the vents from being connected, thus no vent.
That problem produced the results you are describing.
Good Luck!
Post A Followup
: Re: Re: BAD FLOAT??
