Re: IH444 lift jerking
Posted by Haas on September 22, 2001 at 08:08:34 from (129.37.117.7):
In Reply to: IH444 lift jerking posted by chris mf35 on September 21, 2001 at 18:36:36:
Turn off the valve that holds the lift up and then see if the lift still goes down. If it does, then you have a bad cylinder/piston. It it stays up when you close the shut off valve, then your control valve is bad. Likely it is a bad seal on the piston. I had a 424 with this same problem and had to replace the piston, because it was worn to bad to replace the seal. I suppose the 444 is the same as the 424, which had a leather seal on the piston. To replace it with a more modern O ring, you will have to take it to a machine shop to have a groove cut for an O ring. However, in my case, the piston had been rubbing on the cylinder and was worn too badly to do this and the piston had to be replaced with a new one. The part is quite expensive from IH. The mechanic that did my work knew that the parts from a Mahindra tractor would fit. He used a Mahindra lift piston and it fit perfetly and cost less than 1/2 of the IH part. You'll have to drain the fluid and take the top off the hydraulic unit to get to these parts.
Home
| Forums
Today's Featured Article -
The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
