Re: BAD FLOAT??
Posted by Bill Smith on September 22, 2001 at 12:30:10 from (128.242.4.59):
In Reply to: BAD FLOAT?? posted by THatOtherGuy on September 20, 2001 at 18:28:26:
You should be able to find a setiment bowl in a salvage yard for little or nothing. Any H setiment bowl will work. As for your carb problem when it is leaking fuel out the bottom of carb, shut the fuel valve off under the gas tank. There should be a gas shut off valve just above the setiment bowl on an original setiment bowl assembly. (Not sure if you are missing the valve as well as the setiment bowl.) This will keep fuel from running out of tank and onto ground. Don't try running the tractor with this carb problem becuase you air fuel mixure for engine is way to rich. Your carb problem is one of the following. Bad shut off needle valve in carb, or a hole in the float allowing it to sink, a stuck float or valve, wrong fuel level adjusted by float, or I have had the pin that the float hinges on work its way out of one of the holes. The pin should be placed in the holes and then crimped so it will stay. You will have to take carb apart and inspect it to see what is causing the valve to not shut off.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
