Re: Help putting tube in tire
Posted by Farmer Bob on September 23, 2001 at 09:17:04 from (208.49.9.103):
In Reply to: Help putting tube in tire posted by Jim on September 23, 2001 at 08:53:08:
Jim, Hopefully you aren't trying to put the tire on the rim with the tube in the tire. Best way I know of to mount the tire is to lay the rim on a good hard clean surface with the valve stem hole facing upward. Mix up some soapy water and sponge down the beads of the tire. Lay the tire over the rim at an angle and put your foot on top of the tire at the low side. Take a couple of big screw drivers or, if you have them, use tire irons. Work the lower bead onto the rim. Once on, now insert the deflated tube into the tire and work the valve stem into the hole ensuring that you pull the valve stem firmly into the hole. Now start working the upper bead onto the rim the same way you did the first bead. Make sure you don't pinch the tube with the end of the tools you are using or you could end up repatching the tube. Once the top bead is under the rim, slide the tire around until the valve stem is straight with the hole and make sure you remove the valve core from the stem. Inflate the tube to seat the beads of the tire. Let most of the air escape from the tube which helps to ensure there are no wrinkles in the tube. Now put the core into the stem and re-inflate to desired pressure. Put the valve cap on and remount the tire. If all this fails, take the tire and tube to the tire shop and let them do it. Sometimes it's worth the money to admit defeat. I know because I just did it this week. I took it back to where I bought the new tire and they mounted it for nothing.//FB
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
